Quick Drop Enthusiasts
Quick Drop Keyboard Shortcut – Arrange VI Window
I use a laptop and my main monitor is my external display, but my "primary monitor" as Windows sees it is the laptop display. I wasn't aware of a way to switch which monitor is the primary one in Windows (I don't see it in the Display Settings area, though I admit I didn't look TOO hard).
I got the setting changed in Resize BD and Resize FP and it works great now. Thanks for the tip 🙂
Message 11 of 49
(7,502 Views)
I'm glad you got it working. Can you PM me screenshots and/or VIs that include the fix? I figure other users may want this behavior, and since we already have a bunch of other INI tokens that let you tweak the plugin behavior, we could add one for this as well.
Message 12 of 49
(7,500 Views)
Sure thing, PM coming soon.
Message 13 of 49
(7,493 Views)
Well it looks like I can't send files via PM, so here they are.
I made mods to Resize BD, Resize FP, and Establish Window Bounds. Establish Window Bounds just includes the new height and width, which could probably be determined elsewhere but I did this in about 20 minutes and didn't fully digest all of the upstream info.
Resize FP and BD are changed to retain the original Top and Left values, then add the Height and Width calculations.
One small "issue" I noticed (not sure if this was in before my mods or not) is that the FP window width is often a fair bit wider than actually needed. It looks like it's trying to keep all tools visible, which is 100% fine by me but I wanted to point it out in case that was just a coincidence.
Thanks for putting this tool out there, it's saving me gobs of time already.
Message 14 of 49
(7,481 Views)
Thanks for posting the updated files. And you're right, we're giving the panel and diagram a minimum width to accommodate all the buttons on the toolbar.
Message 15 of 49
(7,478 Views)
Darren,
I would love a INI file key to be able to override the minimum width behavior. 😁
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
Message 16 of 49
(7,469 Views)
@CL_eisenwr wrote:
Darren,
And I would *love* if every VI I opened had a fully visible toolbar that I could use. 😉
But yeah, this would be easy to add an INI token for as well.
Message 17 of 49
(7,464 Views)
P.S. - I filed myself Bug 1016812 to see about adding the tweaks described in this thread as additional INI tokens in a future LabVIEW release.
Message 18 of 49
(7,461 Views)
CL_eisenwr, Have you tried using ArrangeVIWin.BD.MinWindowWidth and ArrangeVIWin.FP.MinWindowWidth to change minimum width of the windows?
Kosta
Message 19 of 49
(7,454 Views)
BertMcMahan, Thank you for the feedback!
Kosta
Message 20 of 49
(7,451 Views)
