04-27-2020 05:15 PM
Darren, Thank you for excellent support!
05-14-2020 01:48 AM
I am a big fan of this plugin and use it all the time 😁
But it does not know how to handle the labels of an image control or indicator.
Now I end up spamming this plug in with the default Ctrl+T to get the labels under control.
Any chance we can get a fix for this?
My example is from the LV2019 version, but I also have this issue when I am using this community version in LV2018
05-14-2020 01:30 PM
There is a bug in scripting with setting the label position of Image controls. This has been reported to LabVIEW R&D as Bug 166545, and will hopefully be fixed in a future LabVIEW release.
07-10-2020 09:54 PM
Hi Kosta,
Like the shortcut and will use. One thing I'm wondering is: Is there a way to REDUCE the default auto-fit VERTICAL SPACING OF FP OBJECTS?
07-11-2020 02:57 PM
@golfman wrote:
Hi Kosta,
Try setting experimenting with the LabVIEW.INI file keys. I think you might like ArrangeVIW.FPObj.VerticalMarginFactor=1
07-11-2020 11:31 PM
Thanks Kosta!
Adding the following to my .ini file
...VerticalMarginFactor=1 #2
...VerticalSpacingFacor=2 #3
is better than defaults shown above with #.
Also, I have learned that LV ignores anything after the # on the same row in the .ini file. This is useful, for me, to remind myself what is the default value.
10-07-2020 03:15 PM
@Kosta wrote:
The Arrange VI Window plugin arranges front panel controls based on the connector pane. It also resizes and repositions both front panels and block diagrams to minimize white space and position windows near the upper left corner of the screen. Windows are sized and positioned based on the size of the monitor. If there are too many items, only a portion of the content is shown.
This shortcut is intended for use with LabVIEW 2014 through 2018.
In LV2019, the Front Panel Clean-up feature was included (Ctrl-U). As a relatively new LV user, I'm starting to learn the built-in QD shortcuts. From what I can tell, using this shortcut on the Front Panel is identical to Ctrl-U on the Front Panel.
(Behavior is obviously different on the BD.)
Are there any differences between Ctrl-U and 'Ctrl-Space Ctrl-F' when used on the front panel?
-joeorbob
P.S. Yes, this shortcut was "intended for use through LV2018". But I'm pretty sure this is the Ctrl-F shortcut included with LV2019, so I'm asking the question here instead of in a new thread. 😊
10-07-2020 03:22 PM
In LabVIEW 2019 and later, pressing Ctrl-Space, Ctrl-F on the front panel performs the same operation as pressing Ctrl-U.
10-07-2020 04:34 PM
@joeorbob, You are correct about the inclusion in LabVIEW 2019 (and later). That is precisely why I wrote the quoted statement - there is no reason to download the code from this page for those versions of LabVIEW 😊
10-08-2020 09:39 AM
I have been using the built-in LabVIEW 2019, and seen a slight difference for the front panels for Ctrl+U and QuickDrop. Ctrl+U does not work on controls, but the quick-drop does resize window. I am not sure if the difference is expected or not.
