12-04-2009 05:43 PM
Attached below is the Quick Drop Keyboard Shortcut template VI I plan on shipping in LabVIEW 2010. All new shortcuts in 2010 should be based off this template. Note the new data that is passed in and out via the variant input/output.
Let me know what you think, and if there's anything I should add/remove/modify.
-D
P.S. - There will be a missing subVI...it just takes the variant input, and outputs a boolean indicating whether or not QD was launched from a panel or diagram.
12-06-2009 07:35 PM
Great template - I am glad that the undo stack is setup in the 2010 template.
I posted this one to LAVA a while back - in case anyone wants to use for templates in 2009.
http://lavag.org/topic/11418-quick-drop-plugin-template/
One question I have:
If the boolean value to close the window in 2010 is TRUE, does that mean a 2009 QDP run in 2010 will not close the window (as there will be no input)?
Do we have to add support for this or is it handled somehow?
Cheers
JG
12-07-2009 10:53 AM
The framework will handle this...no worries on your side. I check if the value coming back from the plugin is valid...if not, I close QD. If the value is valid (and it's FALSE), then the combo box is cleared and QD remains open.
-D
12-21-2009 12:50 AM
Thanks Darren
