Quick Drop Enthusiasts
Move Terminal Labels.vi
Here is my update for the Move Terminal Labels.vi plugin. This is only valid for LabVIEW 2012 and beyond.
Change List:
  1. Respect LabVIEW.ini tokens for label placement
  2. Added Front Panel capability, if the label is visible it moves the label as specified in the LabVIEW.ini file. If the Label is not visible and the caption is, then it moves the caption as it would the label.
  3. Justifies the text as following:
    1. Top Left, Bottom Left, Right Top, Right Middle, Right Bottom = Left Justify
    2. Top Right, Bottom Right, Left Top, Left Middle, Left Bottom = Right Justify
    3. Top Middle, Bottom Middle = Center Justify
I would recommend overwriting the default Move Terminal Labels with this one (be sure to back up the original file). Please let me know if you have any suggested improvements
Special thanks to Darren Nattinger for code review and early feedback. Please feel free to incorporate these changes into LabVIEW 2013.
Update: Darren was able to incorporate these changes into LabVIEW 2013. This update is only needed for LabVIEW 2012.
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
Message 1 of 1
(8,913 Views)
