Quick Drop Enthusiasts
Reply
Re: List of Community Quick Drop Keyboard Shortcuts
I put a control down and ment it to be a typedef, it changed a few times while I was coding. The replace quickdrop shortcut is a life saver, but if i didnt have to type the name every time to replace it would be a slight bit faster.
Message 11 of 18
(688 Views)
Record the ctrl used in a text file for later used.
This VI has the information of the ctrl:
C:\Program Files (x86)\National Instruments\LabVIEW 2013\resource\dialog\QuickDrop\QuickDrop Launch Window.vi
Message 12 of 18
(688 Views)
try the newly uploaded shortcut:
Paste-replace sub VI
Message 13 of 18
(688 Views)
I modified someone elses VI to include showing/hiding labels for block diagram objects.
https://decibel.ni.com/content/docs/DOC-47643
Message 14 of 18
(688 Views)
Is there some quick-drops, to insert breakpoint? I know that it could be done by right-click, but with quick-drop it could be faster... And if such quick-drop does not exist, is there a way, of how to add breakpoint to block diagram? I've googled a bit, but didn't find the info...
Thanks a lot in advance!
Message 15 of 18
(379 Views)
You could try using LVHotkeys. You just hover over the wire and press b on the keyboard to set/unset a breakpoint.
Message 16 of 18
(370 Views)
It could possibly be faster with a quick drop, but what I always do if I plan to drop more than one is "Shift-Right Click" switch from auto tool to the break point tool.  Then you can just click to drop as many as you want.  Same goes for probes (I use that one a lot more often).
Certified LabVIEW Architect
Message 17 of 18
(362 Views)
I think this kind of operation is better with a custom right-click menu, particularly since you can't use Quick Drop at runtime, but you may want to set a breakpoint at runtime. We already have a custom right-click for moving the breakpoint menu options up into the top-level right-click menu, see here.
DNatt, LV R&D
Message 18 of 18
(356 Views)
Reply
