06-30-2014 01:03 PM
You are right, I am crazy. What I was trying to say is that if you perform an insert on a wire that has mulple sink locations, the insert should be between that sink, and the next junction of wires. I swear in my testing your insert wouldn't obey this rule that was added in 2012. 2011 insert couldn't support this type of insert.
EDIT: No now I'm sure your insert, when using the clipboard, will not always insert on the right branch of the wire and I suspect it is a bug with the "InsertPoint" input on the Insert Node Invoke Node, I just don't know where the bug is yet.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
06-30-2014 01:33 PM
Okay I found the bug. Determining what segment of the wire the insert should take place on, depends on the flags of that segment. Apparently if you paste in an object on the block diagram, these selection flags change, and now your insert won't take place at the right location. A quick solution is to read the "Joints" information, before performing the paste operation and now it works as expected.
07-01-2014 12:34 PM
07-01-2014 09:18 PM
