Quick Drop Enthusiasts
Ctrl+T on the Front Panel to move labels of controls & indicators
How about moving all labels or captions of selected controls & indicators to the right side when Ctrl+T is used on the Front Panel?  It would be nice when you want to stack a bunch of booleans or numerics (especially when taking advantage of vertical arranging in clusters).
(4,385 Views)
The intent of the Ctrl-T shortcut is to apply your Tools > Options settings to label positions on objects. If your settings are "Classic" (the default), then the diagram terminal labels get moved onto the sides, but the panel labels get moved to the top-left. If you want Ctrl-T to move them to Left-Top and Right-Top for controls and indicators on the panel, respectively, then you'll need to change your Tools > Options settings appropriately:
(3,471 Views)
