Quick Drop Enthusiasts
Crash on Undo after Insert VI on multiple wires
If I insert a VI on multiple wires (CTRL-SHIFT-I) then try to undo it (because it decided to reroute a bunch of wires and mess up my diagram) LabVIEW will crash about 50% of the time.
Has anyone else seen this?
Anyone have a work-around?
thanks,
-John
-John
Certified LabVIEW Architect
(5,399 Views)
I frequently use Ctrl-Shift-I, although I'll admit I don't undo it that often. Your "50%" comment tells me that it's not particularly reproducible for you, but if you manage to reproduce it with a codebase that you can share with me, I'll definitely CAR it so we can investigate.
(3,335 Views)
I demonstrated this very feature on a LabVIEW RT vi today, and used Ctrl-Z to undo, with no ill effects.Never had a problem in the past. I use LV 2014.
(3,335 Views)
Not sure if I can localize it that much.  I see it in complex code that is part of a very large system with tons of static dependancies.
If it helps, it usually happens when the wires I am inserting into have been branched just before and routed to other parallel parts ofthe diagram.
If I can get a consistent crash I will post it here.
-John
(3,335 Views)
