Q&A ๊ฒŒ์‹œํŒ
Showing results forย
Search instead forย
Did you mean:ย
RT scan engine mode goes into configuration mode when error 66464 happens.
I'm using RMC-8354 and sometimes error 66464 happens and scan engine mode goes into configuration mode, however when I reset RT, it turns active mode again. I'm using several RMC-8354 servers but only one RT shows this error. I suspect this is uniquely from only one RT. I already googled and what is the meaning of error 66464. What I do know is how to fix it. not just information. I contacted some channels but answer was not okay to me. Please give some ideas of this problem. Thanks in advance!!
Best Regards,
(265 Views)
Hi  gooohestpoo,
Have you tried comparing the software installed on a normal system with the software on the problem system?
As you know, error 66464 can happen when the iteration period of NI scan engine is changed.
I think checking the configuration of the system is a good start point to resolve it.
(248 Views)
Highlighted
Hi Chan82,
Thanks for your response. ๐Ÿ™‚ I checked installed software series from MAX compare with other RTs, but couldn't find any specific weird one. I guess this is not the root cause right now.
Thanks for your comments anyway.
Best Regards,
(241 Views)
This is a description of error 66464.
The global time on the controller was altered, which might affect the period of an iteration of the NI Scan Engine. A timing source such as IEEE-1588 or GPS modified the global time value on the controller. This can result in a temporary phase shift, which would alter the update period for NI Scan Engine variables for one iteration.
Please check the time of the controller time.
(226 Views)
