01-30-2019
03:12 PM
- last edited on
08-05-2025
04:30 PM
by
Content Cleaner
A common request from design teams developing power converter systems based on the sbRIO-9607 GPICs and/or sbRIO-9687 Semikron Universal Interface is the exact contents of each NI shipping kit. You can find the shipping kit contents listed below. The quantity for each item is listed in each row and column, with a blank cell indicating quantity 0.
| 785254-01 Dev. Bundle, NI 9684 GPIC 16-bit 180 kS/s, sbRIO-9607 Zynq-7020 (45 Day Software License, Thermal Heat Sink Kit, Desktop Power Supply, Standoffs, Screws, Power Connector, CAN/Serial Cable) $1754 | 785256-01 OEM Bundle, NI 9684 GPIC 16-bit 180 kS/s, sbRIO-9607 Zynq-7020 (sbRIO-9607, NI 9684 GPIC, Thermal Heat Sink Kit, Standoffs, Screws, Power Connector) (Call) | 785258-01 Universal Semikron Interface Bundle w/ NI 9684 GPIC, sbRIO-9607 (45 Day SW,Thermal,Power S.,Acc.) $2499 | 784491-01 Development Bundle, NI sbRIO-9607, NI 9683 GPIC (Thermal Kit, Power, Standoffs, Accessories, 45 Day Software) $1644 | 784493-01 OEM Kit, sbRIO-9607, NI 9683 General Purpose Inverter Controller (GPIC), Thermal Kit, Standoffs, Screws (Call) | NI Orderable P/N | Part Description |
| 1 | 1 | 1 | 1 | 1 | 783816-02 | SBRIO-9607, ZYNQ-7020 FPGA, 220 DSP CORES, 667 MHZ DUAL-CORE PROCESSOR, RT LINUX |
| 1 | 1 | 1 | 1 | 1 | 153901-02 | THERMAL HEAT SINK KIT REQUIRED FOR SBRIO-9607/9627/9637 AND QTY 4, STANDOFF AND SCREWS, sbRIO to PANEL, 16MM LONG, M/F, M3X0.5, SS WITH SCREWS, 8MM LONG, M3, PHIL, PNHD, SS, WITH NYLON PATCH |
| 1 | 1 | 782592-01 | CCA, NI 9683 GPIC Industrial Multifunction I/O for sbRIO-9607, sbRIO-9606, sbRIO-9605 only | |||
| 1 | 1 | 1 | 785257-01 | CCA, NI 9684 16-bit 180 kS/s GPIC, GENERAL PURPOSE INVERTER CONTROL I/O BOARD | ||
| 1 | 785636-01 | NI 9687 UNIVERSAL SEMIKRON INTERFACE BOARD FOR NI GENERAL PURPOSE INVERTER CONTROLLER (PCB,STANDOFFS) | ||||
| 1 | 785637-01 | MOUNTING PLATE UNIVERSAL SEMIKRON INTERFACE BOARD FOR NI GPIC | ||||
| 1 | 786176-01 | PLUGGABLE CONNECTORS, UNIVERSAL SEMIKRON INTERFACE BOARD FOR NI GPIC | ||||
| 1 | 1 | N/A | NON-INDUSTRIAL AC-DC POWER SUPPLY, 90-264 VAC IN, 12VDC OUT, 18W, 2 POSITION, CONN, MALE, MINI-FIT JR, DESKTOP USE ONLY | |||
| 1 | 1 | 151733-02 | Cable Assembly, CAT-5E Ethernet, Thin Profile, Shielded, 2M | |||
| 1 | 1 | N/A | DVD KIT, LABVIEW RIO EVALUATION SOFTWARE 2015 (LABVIEW, REAL-TIME, FPGA, RIO), 45 Day | |||
| 1 | 1 | N/A | DVD KIT, LABVIEW 2015 FPGA XILINX COMPILATION TOOLS ,WINDOWS | |||
| 1 | 1 | N/A | DVD KIT, MULTISIM EVALUATION V14.0 - PROFESSIONAL | |||
| 1 | 1 | N/A | SCREWDRIVER, NI LOGO, SLIM 100 BLADE, #1 PHILLIPS TOP | |||
| 1 | 1 | 1 | 1 | 1 | MANUAL, NI 9683/9684 USER GUIDE AND SPECIFICATIONS | |
| 1 | 1 | Link | MANUAL, NI SBRIO-9607 GETTING STARTED GUIDE | |||
| 1 | 1 | MANUAL, NI SBRIO-9607 USER GUIDE AND SPECIFICATIONS | ||||
| 1 | 1 | 1 | 1 | 1 | 152834-01 | sbRIO POWER CONNECTOR CABLE ASSY, MINI-FIT PIGTAIL, 2C, 12IN |
| 1 | 1 | 1 | 1 | 1 | 141158-04 | QTY 4, STANDOFFS AND SCREWS, sbRIO to RMC, 9.65MM LONG, M/F, M3X0.5, SS, NP WITH SCREWS, 5MM LONG, M3, PHIL, PNHD, SS, WITH NYLON PATCH |
| 1 | 1 | 1 | 1 | 1 | 141161-04 | QTY 4, STANDOFFS AND SCREWS, RMC to I/F PCB, 11.12MM LONG, M/F, M3X0.5, SS WITH SCREWS, 5MM LONG, M3, PHIL, PNHD, SS, WITH NYLON PATCH |
| 1 | 1 | 1 | 1 | 1 | 141160-04 | QTY 4, STANDOFFS, RMC to Panel, 29.81 MM LONG, M/F, M3X0.5, SS, NO SCREWS |
| 1 | 1 | 1 | 1 | 1 | 141159-04 | QTY 4, STANDOFF AND SCREWS, I/F PCB to Panel, M3X0.5, 4.5MM HEX, 43.36 MM LONG, M/F, SS AND SCREW, 5MM LONG, M3, PHIL, PNHD, SS, WITH NYLON PATCH |
| 2 | 2 | 153158-10 | sbRIO CAN/SERIAL CABLE ASSY, 10POS IDC FEMALE TO 9POS DSUB MALE | |||
| 8 | 8 | N/A | QTY 1, NUT, M3X0.5 |
05-05-2020 10:30 AM
Now that NI has launched the NI-9608 and the NI-9609, will these next-gen sbRIOs be bundled for Power Electronic applications?
06-04-2021 12:51 PM
1) the 9608 and 9609 are compatible with GPIC and Semikron boards.
2) NI will no longer offer the bundles, but the products can be ordered separately
If anyone needs more info, PM me. I'm researching this for myself and helping a few customers make plans for next generation development or replacing EOL products.
