Power Electronics Development Center
Two FPGA bitfiles running parallel on sb-rio 9607
I am developing a small scale microgrid system which I have to run two bitfiles run on the FPGA target simultaneously. I tried putting two separate FPGA VI references on the same RT application, but it seems like only one of the two references is running. Could anyone help me with this issue? or Is it even possible to run multiple FPGA bitfiles simultaneously?
(5,832 Views)
Can you give some details of which modules are you using, or is it a simulation?
(5,817 Views)
Accepted by incasekim
Only one bitfile can run at a time.
ALE Consultants
(5,807 Views)
