Power Electronics Development Center
LabVIEW FPGA PMW generation for L298n H-bridge
Hello to everyone,
I am new in LabVIEW FPGA programing and I have a couple questions, so I would be grateful if you could answer me. For my final work I have to control the speed and direction  of DC motor  using sb-RIO 9636 and H-bridge L298n. In attachments you can find scheme of the H- bridge and my program. I have conected In1(pin 5 of L298n) to digital pin 1 of the card, In2(pin 7 of L298n) to digital pin 2 of the card and changing the state of the pin I change the direction of the motor(I know that the one In should be Low and the other High so the motor can rotate  in one or the other direction). PWM(Enable pin of the L298n pin 6) I have conected to DIO3.
PWM signal I cretaed is  shown in picture.
My questions are:
1.Will loop timer I used, provide that period of signal is lenght I specify in the control(for example if I put 20 000  will the period be 20000 s)?
2. Can I vary the duty cycle changing the control Waiting (DIO3 is HIGH for a couple of us, then it sets LOW, and then all that repeats )?
3. Earlier I thaugt that PWM signal I should send in both IN1 and IN2, and that the Enable pin is used to stop or start the motor. I tried that and the motor was rotating different speed, and I could stop or star the motor with enable pin, sending it HIGH OR LOW, but I could not change the direction of the motor. So my other option was to conect the pins as I explained at the begining.  My question is: Should I PWM conect to the enable pin, and will thah work?
Thank you
Message 1 of 1
(3,419 Views)
