Power Electronics Development Center
How can I see a signal generated for the sbRIO in the PC as simulation?
Hi, I'm starting to work with sbRIO-9606 and with LabVIEW, I have many doubts, the biggest one is, how can I see a signal that I programmed for the sbRIO in my PC as when I simulate, I mean, isn't there an virtual oscilloscope to see the signals generated for the FPGA?
Thank you veery much
(4,158 Views)
Check out these tutorials:
Testing and Debugging LabVIEW FPGA Code
Using the LabVIEW FPGA Desktop Execution Node
-spex
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
(3,753 Views)
