Power Electronics Development Center
Can two SBRIO 9606 with NI 9683 connected to a single PC( two LAN ports are available)
l am developing a experimental setup for Microgrid. A single FPGA boards i/o ports, analog ports and digital i/o ports are not sufficient. Can i add another FPGA( SBRIO with NI 9683) to the same system.
(3,724 Views)
Accepted by topic author Akshaya_pati
I have used that setup with no problem. Naturally, you have to include both boards in the project manager, each with its distinctive IP address, as well as their corresponding RMCs.
Biscay.
(3,713 Views)
