02-11-2020 04:40 AM
I am using a QuickSyn FSL0010.
I manage to communicate with him via NI-MAX and the VISA test panel.
All commands work except those related to the RF output.
OUTP: STAT ON / OFF -> Does not change the RF output state
OUTP: STAT? -> Returns an error
This QuickSyn is integrated in an automatic test bench, so I must be able to use these commands
Anyone have an idea?
04-07-2020 04:18 AM
Hello
You can use 02 command to get output state and use 0F01/0F00 to enable or disable the output, see detailed command description in attached screen shots.
Frank
04-07-2020 04:30 AM
Thank you for your reply.
But I don't want to use SPI commands
I need these functions but with SCPI commands
Vincent
04-07-2020 05:25 AM
Hi Vincent
These two commands also can be used as SCPI, you can try it as showed in attachment. Seems that commands OUTP: STAT ON / OFF and OUTP: STAT? are not supported on FSL-0010, we had the same situation before.
Frank
04-10-2020 03:10 AM
Hi Frank,
OK, thanks. I'm not on site these days.
As soon as possible I will try
thanks again
Vincent
04-17-2020 09:05 AM
Hi Frank
It works with commands 0F01 / 0F00.
Thanks again for your help
