Past NIWeek Sessions
Rapid Control Prototyping and Hardware-in-the-Loop Simulation of an Engine Controller
Abstract: Discover how you can set up an engine control prototyping unit using NI Powertrain Controls modules and then perform hardware-in-the-loop test on an engine control unit (ECU) using NI VeriStand. Also learn how you can use CompactRIO and NI PXI hardware to develop and test an ECU.
Track/Summit: Transportation Summit
Speaker(s): Stephen Barrett, Systems Engineer National Instruments Corporate
Contributors
