PXI
what is the pinout of the 192568-1 cable
What is the ene to end pin out of the 192568-1 cable assembly.  I am looking to see if the pin out lines up with the 16036 cable from Ballard
(4,500 Views)
Hi racleave,
The pinout of the cable slightly changes depending on which module you are using but the data is always transfered over the same pins and yoru commons remain the same. Take a look at these specification documents to see the pinout of the modules. The cable pins correspond directly to the DSUB pinouts of these modules. Look at page 8, 9, and 8 respectively of these specification sheets.
https://www.ni.com/docs/en-US/bundle/ni-9472-getting-started/page/overview.html
https://www.ni.com/docs/en-US/bundle/ni-9401-getting-started/page/overview.html
https://www.ni.com/docs/en-US/bundle/373783h/resource/373783h.pdf
I hope this helps, have a good one.
Paul C
(4,453 Views)
