PXI
veristand Deployment Error
Hi All,
I am getting the following error please help me solve this.
Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi
<append>=========================
NI VeriStand: VISA Unmap Trigger in NIVeriStand Trigger Routing.lvlib:Unmap TTL0 from all trig bus segments.vi->NIVeriStand Trigger Routing.lvlib:Setup Chassis Routing.vi->NI VeriStand Engine.lvlib:VeriStand Engine State Machine.vi->NI VeriStand Engine.lvlib:VeriStand Engine.vi->NI VeriStand Engine.lvlib:VeriStand Engine Wrapper (RT).vi
Error -1073807360 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi
Possible reason(s):
VISA: (Hex 0xBFFF0000) Unknown system error (miscellaneous error).
Thanks in advance,
INFENT
(2,179 Views)
I fixed a very similar deployment error (0xBFFF0010) by re-installing the VISA driver in NI Package manager. It is important to reboot after removing it, install it and reboot again
(1,393 Views)
Came accross this again, but this time the fix was to power down the PXI chassis and host PC. Unplug the power cables for 10 seconds, then reboot
(351 Views)
