08-02-2018 05:10 PM
I have a PXI-6683H card in a PXIe 1085 Chassis with multiple Ballard Avonics Cards:
1 - 16 channel ARINC 429 (784803-01/LV-222-441-000)
2 - 4 channel MIL-STD-1553 (784798-01/LV-222-511-511)
3 - 32 channel ARINC 429 (784804-01/LV-222-442-442)
I want to feed my external IRIG source to my 6683H card and the Ballard cards. How can I accomplish this without losing any connections to my bus channels?
08-03-2018 08:19 PM
Hi Faustina, I have done a bit of searching on this matter and found this document that you can use to get started with the GPS synchronization using the 6683H http://www.ni.com/tutorial/53314/en/ to use this with your Ballard cards you will need to consider the following:
Keep in mind that a couple of SW components are going to be needed here.
If you have further questions about this feel free to reach out to support through a Service Request, you may find more resources to get assistance for this issue if needed.
astromaut
