06-21-2018 06:21 AM
Hello All
I use PXIE 1085 and I want to synchronize the SMU(PXIE 4139) with NI RFSA (PXIE 5840). how can i do this?
I used the way for the synchronizing the SMU and PXIE 5840 (I attached its picture), however in this method I need a VI which gives the NI DCPOWER GET SESSION REFERENCE, and i cant find it in the NI DCPOWER palette.
Solved! Go to Solution.
06-27-2018 04:05 AM
Hi yashar93,
You could try using NI-TClk to allow multiple instruments to simultaneously respond to triggers, to align Sample Clocks on multiple instruments, and/or to simultaneously start multiple instruments. More information can be found here:
http://zone.ni.com/reference/en-XX/help/370956M-01/nitclk/nitclk_overview/
06-27-2018 06:45 AM - edited 06-27-2018 06:47 AM
"Hello Kelly_ Chan
yes i wanted to use NI TCLK to synchronize them, but if i want to use NI TCLK first of all i should enable the NI TCLK for NI DCPOWER and in this link , they mentioned a method for this aim. but the problem is here, i cant find solution explorer in LABVIEW to do the mentioned steps.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019SOrSAM
my problem is here " In your project, add a reference to the NationalInstruments.ModularInstruments.Common assembly. Right-click References in Solution Explorer, select Add Reference"
since i cant find solution explorer.
06-27-2018 06:48 AM
"Hello Kelly_ Chan
08-17-2018 10:49 AM
i found the answer. if you want to synchronizing the SMU with RFSA (PXIE 5840) should use the back plane and send trigger from PXIE 5840 to SMU, to start trigger
