PXI
start and Pause the Acquisition based on the PXI Chassis Trigger line
In PXI 6341 Card is it possible to start and Pause the Acquisition based on the PXI Chassis Trigger line for Indvidual IO Lines Parallelly.
(1,429 Views)
Yes, see NI-DAQmx Data Acquisition Triggering Techniques Using LabVIEW
No, there is only one AI timing engine in a DAQ device. You could use the counters to generate more sample clock, but you can only have at most 1+4 distinctive AI tasks.
https://tmesystems.net/
(1,401 Views)
Thanks for the reply ZYong,
     Is it Possible to read the PXI Chassis Trigger Lines in DAQmX Channels?
(1,382 Views)
I never tried that, but I think you can use DAQmx Connect Terminals (VI) to route a trigger line to a PFI of digital task.
(1,370 Views)
