‎11-18-2013 10:41 AM
How can I configurate the pxi4132 to the best sensitivity - 10pA to current measures in the 10uA of range?
Solved! Go to Solution.
‎11-19-2013 10:49 AM
‎11-19-2013 11:31 AM
In your manual is wrote: "For instance, on the 10 μA current measurement range, you can typically achieve 100 pA sensitivity at up to 1000 readings per second."
I understand this is not true. Is true for 10uA currente measurement range, we have 900pA sensitivity...
‎01-24-2018 06:32 AM
Dear Abel,
How do you configure the smu PXI-4130 to work by supplying 5V with 1.5A through the CH0 or CH1 output channel using the auxiliary APS-4100 (12V output)?
Seixas
