06-11-2007 09:25 AM
06-12-2007 11:50 AM
Hello dcwill,
I am not sure if it is even possible to create a read-only drive and run LV RT from there. I assume you would like to convert the drive to read-only after installing LV RT components on it.
You can save your data to an external hard drive, which is connected through a USB connection (there is no FireWire option on the 8196RT controller). The hard drive will be accessed as the U drive. You can also place your rtexe on the external hard drive and change the corresponding token in the NI-RT.ini file. See this KB about RT tokens.
Hope this helps!
06-12-2007 02:11 PM
I have been told that the USB port is not supported by Labview RT. But that was with version 7 and I am using version 8 now. Does v8 support USB? I have plugged in a USB flash drive, formatted to Fat32 and the system can not see it. As drive u or any other letter. I wrote an program to get the drive info for all the drive letters. Only drive c returned without an error.
I have used firewire drives in the past with Labview RT and an added controller, because USB was not supported.
And the info I have seen to create a bootable USB device is for Windows not Labview RT. So if the USB port is supported under LVRT how do I create a LVRT bootable USB flash drive?
06-13-2007 07:37 PM
Hi dcwill-
You need LabVIEW Real-Time 8.2 for USB support. Please see the following KnowledgeBase articles:
KB 3YQ8O7TQ: Can I Boot into or Run LabVIEW Real-Time Using a USB Flash Drive?This should explain the behavior you're experiencing, and what you can do if you upgrade. Hope it helps!
