PXI
pxie-1073 trigger
Can the PXIe-1073 drive/monitor the PXI trigger lines?
(5,732 Views)
Hello basepolodad,
I would like to show you the following link that show all the specifications of the PXIe-1073. In this document you will be able to see a lot of information on the PXI trigger bus that the chassis has and how we can access it.
  • NI PXIe-1073 User Manual
https://www.ni.com/docs/en-US/bundle/pxie-1073-seri/resource/372768c.pdf
Please let me know if this document addresses your properly question.
Luis C.
(5,657 Views)
Thanks for the reply.
The manual is not clear to me whether the chassis can drive or monitor the PXI trigger bus lines.  If it can is there an example showing how?
Robert
(5,651 Views)
Hello Robert,
I have not seen any software that can monitor and display the information of the PXI Trigger Bus that is in the backplane of the PXI. A workaround is using an external card that can be used to export this lines to the front panel of the PXI. Some of the cards that can help with this are the 6652 or the 6653 timing and synchronization cards.
On the following link you should be able to see an example on how to export a Trigger to a PFI line:
https://forums.ni.com/t5/Example-Code/Using-NI-SCOPE-and-Exporting-Triggers/ta-p/3507845
Also, I would like to show you some articles that speaks how to manipulate the trigger lines:
  • Using PXI Timing and Triggering Functionality
https://www.ni.com/en/support/documentation/supplemental/18/using-pxi-timing-and-triggering-function...
  • Routing PXI Trigger Lines Across the Buses of Multisegment PXI Chassis
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIIVCA4&l=en-US
  • Signal Routing for PXI Devices - NI Digital Waveform Generator/Analyzer Help
http://zone.ni.com/reference/en-XX/help/370520J-01/hsdio/hsignal_routing_pxi/
I really hope this answer properly your question. If not, please let me know so I can see how I can assist you further.
Luis C.
(5,636 Views)
