PXI
pxi-8513 smb connector
I want to use pxi-8513's front panel to trigger pxi-4080.
(448 Views)
Since PXI-4080 only supports PXI Triggers, either you can directly route triggers from 8513 over the PXI Triggers or wire up the 8513 front panel to SMB connector on PXI Controller then route the SMB connector to PXI trigger of PXI-4080.
Here is how to use the SMB connector on embedded Controller - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Uu6SAE&l=en-US
Santhosh
Soliton Technologies
(443 Views)
What should I do to route triggers from smb connectors  to backplane? I just have pxi-8513.
(429 Views)
