I have allready instaled Windows7 Pro 32-bit annd I want to instal Windows7 Pro 64-bit. What is my concerns is that if the NI drivers are fully compliant with Windows7 Pro 64-bit( NI LabView Runtime 8.5,TestStand 2012,NI-MAX 5.3.1,DAQmx 9.5.5,NI-RIO 12.1 and Pickering drivers)
Yes, they should be but to double check I would see if you still have the Readme file to verify. Most, if not all, 32-bit applications will work in 64-bit OS.
Jonathan R. Applications Engineer National Instruments
