Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
12-04-2009 09:19 PM
I want to use PXI-5421, arbitrary waveform generator and external function generator made from Agilent.
Two signals from them should have the common ground.
I found the chasis ground on the back panel of both PXI module and Agilent.
Can I connect each other for my purpose? or other considerations?
In addition, DAQmx (AD, DA, DIO) and signal generator in PXI module has the common ground without futher consideration?
labmaster.
Thanks!
We'll be in touch soon!
