PXI
no LIN-communication PXI-8516
hey to all,
my problem is as follows...
I have 3 PXI-8516 cards for LIN communication, each with 2 Ports. My CPU acts as a master and sends values (U/I/T) to 5 test objects parallel.
In Software it's also written in a parallel code for each channel (test object). Software works perfect for the first 4 channels, but for the 5th channel, I can get no communication.
I have rotated the test objects. There is just a problem with the 5th object. But the 5th object works fine, because, if I'm testing it with CANoe as master, it works.
Does anybody know, if it could be a matter of adjusting the PXI-card?
For more information, feel free to ask
I'm at my wits' end.
(4,649 Views)
you can check whether there is a LIN signal coming out (use a oscilloscope) from the PXI 8516. Even with your DUT, there should be a signal coming out from the 5th channel (since the PXI 8516 is a LIN master).
if there is no signal coming out, try to run your program using the 5th channel only.
(3,962 Views)
