PXI
niRFSG Close.vi Report Error "-1074101887": The register write command timed out.
Recently, when we run test with PXIe-5840 to generate RF CW signal, it pops up Error "-1074101887". And the eror description is "The register write command timed out".
Once this error happens, the RFSG SFP ablo cannot work, whowing the same error info:"The register write command time out". After reset the deice in NI-MAX, the error is gone. However, we continue to met this error from time to time.
Is there any one had this issue before, or know how to fix it? Thanks very much!
BR,
Brian
Message 1 of 1
(1,613 Views)
