09-03-2009 12:56 PM
Need the pin out identification for 761289-16.
Please email pictures or spec. on how housing unit is assembled and wired.
09-04-2009 02:27 PM
Hi balandry,
The following page contains the pin out for the 2565 which connects to the 761289-16.
How to Connect Signals to the PXI-2565
http://zone.ni.com/devzone/cda/tut/p/id/2779#toc2
This is all the information that is available on our website for the 761289-16, if you need more detailed information, post back with what you need and I will check if it is available.
Scott M.
01-11-2021 04:05 PM
Is it possible to get a step/iges file for 761289-16?
Thank you,
01-12-2021 04:02 PM
Those are probably Phoenix connectors and you should be able to get the 3D models from Phoenix
https://stevenengineering.com/tech_support/PDFs/67_PCB-MINI-PLUG-IN-CONNECTORS.pdf
