12-02-2011 01:35 PM
I have PXI 5600 in my lab.Our lab doesnt have Labview antennas But it does have Ettus USRP and its antennas . I can either choose to buy labvview antennas or Can I save the cost by interfacing Ettus USRP antennas with PXI 5600 which are already available in our university's lab??
12-05-2011 01:28 PM
Hi Sabe,
The Ettus USRP antennas should be able to be used with the PXI-5600. However, you will have to check the documentation and specifications of the antenna to see if it will work with your application. You may want to keep in mind that antennas will work better at specific frequencies than at others, and that kind of information should be given in the documentation. Let me know if you have any follow-up questions, thanks!
Joe S.
12-07-2011 12:47 PM
