PXI
how to use TRIG connecotr on PXIe-8135 embedded controller
 I would like to use the TRIG connector on the PXIe - 8135 embedded my software to triggeer the data acquisition. I dont know how use control this connector in software. Can someone please help me?
(7,590 Views)
Hi MansoorEE,
Are you working with a Real-Time system, or is this a Windows-based application?
(7,541 Views)
I am trying to use the SMB TRIG connector as well. We are running Labview RT on the controller. Is there any information on how to use it?
(7,335 Views)
Hi pDub,
First, I'd like to point out:
  • At present time, triggers cannot be routed throught the SMB connector if your controller is running Windows.
  • The SMB connector is intended primarily for use in watchdog timing on RT systems.
  • Trigger allocation is required, so that trigger lines are not double-driven.
Since you are running LabVIEW RT, you should be able to take advantage of the connector.  If you plan to route I/O timing or triggering signals for tight synchronization through the connector, I would recommend that you consider alternative options.
That being said, you'll probably find these examples [link removed; page no longer available] helpful.
(7,322 Views)
Hi kb_MEMBER your link to the usage examples seems to be broken.
(3,693 Views)
