milaus,
the 6608 board has a special feature: it mounts a realtime clock that can be synchronized with a GPS signal in order to provide precise timestamping and synchronization to your application.
If you mean to use a GPS signal for your synchronization, then you would also need a GPS receiver that can pass an IRIG-B signal to the clock line of the 6608. This is very well documented on the 6608 user manual and also on the following Knowledge Base
In case you should only need to synchronize operations between the 6608, 6254 and 6528 (I am not aware of any 6548 board), there are a few things you need to consider:
- the 6528 is a static DIO board. This means it is not possible to hardware clock DIO operations, but only to perform SW polls or event change detections.
- you need to choose which device is going to be the master to your system. The master needs to route it's clock to the PXI_trigger bus and the slave will receive the clock on the same line.
You will find some good examples for synchronizing multiple devices in the Example Finder in LabVIEW
AlessioD
