02-19-2014 12:54 PM
how to generate voltage using pxi-7340?
02-20-2014 06:01 AM
Hi Amged,
It is not too difficult to generate an Analogue Output from a motion card. There are a couple of online documents that describe how to perform AO in MAX and an example of AO control using LabVIEW:
Example
Let me know how you get on with this information.
Kind Regards,
02-21-2014 12:32 PM
Thanks Laurence,
I am using a voltemeter to check my motion controller. The problem with this one there is no guidence for how to wire? I have 68 pins?
For example in max if you use the virtual DAQ device it will show you the connection diagram?
02-24-2014 10:44 AM
Hi Amged,
You can find out the pinout information from the 7340 user manual. I have attached the section here:
I hope that clarifies it.
Kind Regards,
02-24-2014 12:56 PM - edited 02-24-2014 01:07 PM
I performed above mentioned example. I measured the voltage between 32 and 68 for the channel 1. I didn't observed any changes when I used the control slider. The axes are configured for stepper not for servo as recommended in the front panel.
AOA
02-25-2014 07:08 AM
It is working fine.
