PXI
how the connection looks
like for example i buy a module like PXIe 6363 or 6375 the card which i am getting is that card alone?? or will i get another bigger module to connect the I/Os
(830 Views)
Accepted by topic author abishek1212
You will get only the PXIe 6363 or 6375 that you purchased. If you're new to PXI ecosystem, the initial setup cost will be high, as you must have a PXIe chassis and an embedded controller or a PC with MXIe card.
Santhosh
Soliton Technologies
(821 Views)
Or you can get a PXIe-1090 to connect to your laptop via Thunderbolt ports.
But personally I think NI mioDAQ is better if you don't plan to use more PXI modules in the future.
https://tmesystems.net/
(803 Views)
