PXI
how can i synch my PXIe-6356 & PXI-6733?
i have a task to generate an analog signal using the PXIe-6356, and get analog signal from PXIe-6356. The AI & AO tasks have to be synchronized.
I found an example called 'Multi-Device Synch-AI and AO-Multi Rate-Trig Skew Correction.vi'. This example sets the reference clock for both AI & AO devices. But the problem is the 6733 seems dont support this property. So here is my question, how can i synch these two devices? What is the best way for such circumstances?
By the way, where can i learn more about such information?
Thanks a lot!
Message 1 of 1
(3,646 Views)
