04-01-2010 04:14 AM - edited 04-01-2010 04:14 AM
04-02-2010 09:13 AM
I am sorry for bit later reply!
Are you able to change somewhere shutter settings? Although to long shutter time would make more blurred image I think its worth checking it!
Do you see the same problems when you use your in laptop built in camera? Do you notice the same problems when using non NI software for acquiring images?
Regards
Franjo
04-02-2010 01:08 PM
problem is only when i use labview. using program added to tv card there is no problem. Also using notebook camera i don't see that problem. I change shutter settings but still the same.
11-12-2010 11:59 AM
Hello
I have the same scenario as yours and i can't get the camera to work.
So can u please post the vi you used or anything that can help.
Thank you
11-17-2010 08:40 AM
Hi antarr,
I will try to help with your camera problem. Before I go into details I would like to ask you to describe problem more detailed. Could you let me know what kind of camera do you use? Is camera working, working with problems or is not working at all?
Thanks for any further information,
Best Regards,
Wojciech Sommer.
Application Engineer
