04-27-2017 02:13 PM
Attempting to send a trigger from one FlexRio FPGA device to anther along the PXIe-1085 back plane. I can see that NI-Sync has a software trigger but I want the trigger to come from the FPGA application because we need to make timing. I attempted to send the trigger by registering trigger 1-3 on bus 1 and registering trigger 4 on bus 2, which is where both my FlexRio devices are placed. I have routed the triggering and created a software panel from both my flexRio devices to send and recieve triggers but I am not seeing a reaction on either end. What is the best way to implement this and is there any examples of someone talking to two devices using triggering?
04-28-2017 05:44 PM
Can you upload the code you have so far? What modules are you using? Have you tried accessing the PXI_trig lines from an FPGA I/O node? Right click the IO node->Add new FPGA I/O->PXI-PXI_trig#->arrow to right->OK
