Hi all,
I need to externally connect a custom card to a pxie-1071 chassis.
The card would normally sit in slots 3&4 and connects at slot 3 via the 110-pin connector (see attached image for the connector i mean).
Basically i need either a breakout/extender card or a cable to effectively let me plug into this backplane - with the card being connected outside of the actual chassis (required for testing / measurement purposes).
Just wondered if anyone knew of a cable / extender card that would work for this purpose, or where i’d source a 110-pin connector from in a different form factor so i could make a custom cable (one female end to plug into the chassis and one male end to plug into the actual card i want to connect)?
thanks in advance
