02-02-2010 03:08 PM
02-03-2010 01:06 PM
Hello Laerie,
I'm getting the following information about the error:
Possible reason(s):
"Calibration Executive: Invalid data type in UserField DataType. Must be 'NUM' or 'STR'."
I would go through the configuration steps and ensure what values you are settingfor your user settings. Also, can you provide more details when you see the error. I'd like to try and reproduce it on my end. Some screenshots of the error and your input settings would be most appreciated.
Paul C.
02-03-2010 01:24 PM
Hello Laerie,
After doing a bit more searching, I did find some reports of this error with the Agilent 3458A. Can you confirm what calibrator you're using and which version of calibration executive?
Paul C.
02-03-2010 04:00 PM
Thank you for your responce, the attached is the message in whole.
Laerie
02-03-2010 04:02 PM
Hello Laerie,
Can you provide the calibrator / calibration executive version?
Paul C.
02-04-2010 02:09 PM
02-05-2010 11:24 AM
Hello all,
This customer has opened a support request with National Instruments. The issue is being worked on with our R&D group and we will post back the results.
Paul C.
