PXI
enable continuous streaming on PXI 5646R
Hello!,
 i'm new using PXI 5646R. I'm making a program where i send an ASK modulated waveform. This waveform is formed depending on some information i'm receiving. I presume that i can achive this with the streaming mode so i tried to run the example RFSG Arbitrary Waveform Streaming.vi to see if i can base my program on this example, but the property "Streaming Enabled" is not supported for PXI 4656R. Can i perform such a generation with my equipment?. Before initiate signal generation, i need first to write the waveform to the device?. But in all the examples, the waveform is created before initiating the generation, and in my case the waveform may change depending the information i'm receiving.
Thanks for your help!
(3,774 Views)
(3,751 Views)
