04-10-2015 12:15 PM
I have PXI-8119 and want to install a dual monitor I have a StarTech (DP2VGA2) that I want to use but it looks like the windows 7 driver does not support the dual monitor function, do you have driver software for the PXI-8119? or how to get dual monitors working with this system?
04-13-2015 03:10 PM
You can use a second monitor on the display port using a display port to VGA converter.
-Jayk
04-14-2015 08:16 AM
But I can only show the same image on both monitors, I wanted to split the desk top between monitors, could not find driver to support other then the single general monitor display.
04-15-2015 03:21 PM
Check out this link that details how to extend monitor display.
https://support.microsoft.com/en-us/kb/976064
Let me know if that doesn't work for you.
-Jayk
04-20-2015 07:29 AM
No help, I just went with a larger monitor, but also had to install NI video drivers s/w to change the resolution. Thanks for helping.
