11-13-2013 09:28 AM
Using a PXIe-8115 controller in my 1062q. I was wondering if it has Wireless capabilities? Havent received it yet so i was trying to plan if i needed to set up things differently at our facility to icorporate a wired connection.
Solved! Go to Solution.
11-14-2013 01:18 PM
Controllers in general do not have Wi-Fi capabilities. Specifically, this PXIe-8115 only has an Ethernet port on the front and does not have built in Wi-Fi capabilities. Typically, this controller is directly connected over the Ethernet front connection (see below image). However, you could use a USB-Wi-Fi antenna (click here for google search on "Wi-Fi usb adapter" for more information).
I hope this help,
Eric-E
