10-10-2017 12:13 AM
we have PXIe-1085 with PXIe-8381 connected to PCIe-8381 (inserted in PC motherboard PCIe slot x16) via MXI Express x8 Cable. for the software I have LabVIEW 2016 (32bit), NI MAX and we try with Windows 10 x64, Windows 7 x64 and Windows 7 x32. the PXI Driver is V17. BIOS compatibility software
we followed the NI PXIe-1085 Series User Manual and http://www.ni.com/pdf/manuals/373681a.pdf
according to the manual our setup procedure was:
1. Shut down and disconnect power cable of PC and PXI
2. Connect PCIe-8381 to an X8 slot or higher . x16 slot was used in our case
3. Connect PXIe-8381 to PXIe-1085 slot no.1
4. Connect PCIe-8381 to PXIe-8381 with the MXI X8 cable
5- Connect Power
6. Run PC. PXIe-1085 was run eventually.
after that we couldn't detect the PXIe-1085 in MAX
after that we do this steps
First, PCIe-1085 run before power on PC then we power on the PC.
also wasn't help us and we couldn't see the PXIe-1085 in MAX.
all that steps was made with different operating system
1. Windows 10 x64
2. Windows 7 x64
3. Windows 7 x32
we also installed BIOS compatibility software, it didn't help us too much.
Is there any suggestion or solution for this problem?
10-10-2017 04:39 AM
PXI is based on PCI. And PC devices must be detected at bootup. Therefore, the PXIe chassis must be connected and turned on before the computer is turned on.
