Reply
connect SH6850 with PXI-6229
Can I connect two SH6850 cables to the PXI-6229?
The distance between the two connectors on the PXI-6229 is very small.
(1,988 Views)
Re: connect SH6850 with PXI-6229
Hello Kolja.Sta..
Unfortunately, you will not be able to connect a M Series Board like PXI 6229 using SH68-50 cable .The SH68-50 is a cable for connecting 68-pin E Series products to 50-pin accessories. To connect a M Series Board you should use cable like SHC68-68-EPM Shielded Cable. If you need to connect a PXI 6229 board to 50-pin accessories you could use the SHC68-68-EPM vable and an adapter like 68m50f.
For additional information please free to contact your National Instruments regional office.
AmirG
(1,976 Views)
Thanks.
Is an adapter 68m50f available anywhere, or must I build it myself?   I couldn't find any on the NI site.
Kolja
(1,972 Views)
However I found it in the meantime. It's an 68M-50F.
But I still looking for the pinout.  Unfortunately it's not in the ressourcen of the NI site http://sine.ni.com/nips/cds/view/p/lang/de/nid/11818.
I hate the internet presence of NI. It's so incomplete.
Kolja
(1,970 Views)
Hello Kolje,
her the PIN out
http://digital.ni.com/public.nsf/websearch/F27DD615660EB26786256F200046D2EB?OpenDocument
regards,
AmirG
(1,967 Views)
Thanks.
Is this list valid for all dip switches in position SERVO or STEP?  And what's about TRIG and BP?  There is no description, what these dip switches will do with the connection of the pins on both sides.
(1,960 Views)
