09-16-2010 05:57 AM
Hey !!
I want to use ONE RAID array (3TB) for two independent PXI systems. Each PXI system will have a VSA and it will be streaming data upto 200MB/s.. the data coming from both VSA will be stored in RAID connected to one of the PXI systems.
Can I do something like this with a 8375 ?? I dont want to use any other PC. If not, please suggest an alternative to make this model work.
09-17-2010 04:09 PM
Hey Alann,
In response to your question: Yes, you can use one RAID array with two independent PXI systems, but this depends on a lot of factors (modules, slots being used, controllers, entire configuration, etc.). Could you give me more information about your system? I need the following information:
With the answers to the above questions, I'll be able to better answer you question.
09-20-2010 01:49 AM
Hey Sara,
1. Yes, it ‘ll be a daisy-chained with PXIe8375. Can I use one of these PXI systems as a host? Or maybe a third system which ‘ll just have a PXI controller and interface to RAID.
2. Chassis PXIe-1075
3. I 'll have VSA (5661 or 5663) in both systems.
4. One channel on each system, 100/200 MB/s
5. Yes, HDD-8264 …
I am trying to build a stream to disk application on both systems. Some application requirements demand the VSA to be in separate chassis, but i have one storage. So i want to use a common disk for streaming data acquired by both VSAs.
