PXI
change pci bus numbering in pxiesys.ini?
Chassis PXIe 1082
First set-up:
Slot 1 with Controller PCIe 8840
Slot 2 PXIe 7822 PCI Device 0 PCI Bus 16 -> RIO0
Slot 3 PXIe 7822 PCI Device 0 PCI Bus 21 -> RIO1
But if you add a card in Slot 4, you get:
Slot 4 PXIe 7822 PCI bus 19, so this is now recognized as RIO1 and the slot 3 as RIO2.
I would like the RIO numbering with the Sot numbering. The RIO numbering is dependent on the PCI bus.
Can the PCI bus numbers be changed in the pxiesys.ini?
Slot 2 AddressInfo = "PXI0 :: 16-0.0 :: INSTR"
Slot 3 AddressInfo = "PXI0 :: 21-0.0 :: INSTR"
Slot 4 AddressInfo = "PXI0 :: 19-0.0 :: INSTR"
Is it possible to change the PCI bus in the address info in slots 3 and 4 so that Slot 3 has AddressInfo = "PXI0 :: 19-0.0 :: INSTR" and Slot 4 AddressInfo = "PXI0 :: 21-0.0 :: INSTR"?
(4,053 Views)
Accepted by Rokot
Hi Rokot,
Have a look at this link:
http://digital.ni.com/public.nsf/websearch/512E5A28B8B2900886256BDF004E4B78?OpenDocument
Important points to consider:
"For PCI devices, the PCI Device Number (Address) is a function of the PCI bus specifications and the Windows operating system. As such, there is no way to force the value to a specific number. By using virtual channels in your program, however, you can easily reassign the virtual channels to specific devices."
It is also strongly advised not to change this file as it might cause some configuration errors.
Let us know if you have further questions.
(4,000 Views)
