PXI
attenuator
Hello
I want to obtain the serial number and manufacture and model of my attenuator. I am using Agilent M9168x.lv to open it with string PX15::12::0::INSTR. I have been able to get the same information for the agilent signal generator using the attached vi . But I cannot figure out how o get the info for he attenuator.
regards
(5,298 Views)
Hi there,
Do you have access to the manual for the attenuator?
http://cp.literature.agilent.com/litweb/pdf/M9168-90001.pdf
Have you managed to set it up in Agilent Connection Expert?
Does the string you are using match what you see in ACE? Does your code give you any error?
I am not familiar with the driver you are using did you obtain it through IDnet http://www.ni.com/devzone/idnet/idnet.htm?
thanks,
Tim, CLD, CTD
National Instruments (UK & Ireland)
________________________________________________
"No problem is insoluble in all conceivable circumstances"
(5,265 Views)
