08-03-2009 12:42 AM
we want to use labview for mesurment of current and voltage at various points of my PCB board and aquire all data and documentation of same. I might be using more than 24 I/O s
I want to know which PXI will be well suited for my requirement.
08-04-2009 07:54 AM
There is a bit less information. What is the voltage range, current range, do you require isolation, what is the rate of acquisition???
You can contact NI India 08041190000. They will be able to help you configure the system.
