PXI
Which NI instrument can be used to measure complex impedance of a RF circuit? Has anyone used NI instrument and Labview to do the similar task?
I am trying to measure input complex impedance of a RF circuit and use Labview to display the measurement on a Smith chart.
(6,053 Views)
Sampling radio frequency signals requires sampling rates in the GHz rate. There are no current NI data acquisiton products that can measure at those speeds. However, you can control a third-party specialized instrument through LabVIEW using GPIB or serial to accomplish this.
If you are only interested in intermittent impedance values of the circuit and do not require the higher sampling rates, then NI may have some daq modules that you can use. If you provide the specs of the circuit, then NI can help you select the hardware.
Once you have the data acquired, LabVIEW has Smith chart capabilities. There is the Smith Plot.vi located in the Picture Plots section of the Functions Palette you can use.Here's also a link of a Dev Zone example titled "Impedance Matching usi
ng Smith Charts" that you might find helpful.
http://zone.ni.com/devzone/devzoneweb.nsf/opendoc?openagent&DC09A87A6B634117862569DC005F5F9F&cat=FC2238B0E5929B7C8625696B007433DF
(6,052 Views)
